Hi,
I have a project with 5.1 audio but when I compile and test the DVD the resulting compilation only seems to be in stereo.
FYI: The 5.1 audio is generated from a DivX with DVD2SVCD as is the pulldown movie.
DVDlab recognises it as 6channel audio when imported.
Is there something I am overlooking?
Any help or pointers would be greatly appreciated.
DVD Lab doesn't alter the sound files, so it should play back with all channels intact. Once you have compiled the DVD, try to play it back in a software player that can show you the audio details (Power DVD's Show Information option, for instance). If it says you have 5.1 AC3, then you have an issue with your play back (amp, DVD player settings etc)
Read my blog here.
[DVD Lab Pro] Does not accept audio delays
By dom61 in forum Authoring (DVD)Replies: 3Last Post: 3rd Sep 2011, 08:35 -
How to Author AC3 5.1 Channel Audio Only DVD Using DVDLab Pro 2
By Hittz in forum User guidesReplies: 10Last Post: 3rd Apr 2011, 01:05 -
DVD-lab Pro advice for two audio trasks
By blajko in forum Authoring (DVD)Replies: 0Last Post: 20th Jul 2010, 02:33 -
DVD Lab Pro Audio Problems
By Outcast212 in forum Newbie / General discussionsReplies: 6Last Post: 21st Feb 2009, 03:11 -
dvd lab pro audio error
By tomoftenville in forum Authoring (DVD)Replies: 7Last Post: 6th Dec 2007, 17:05
